Hello to all boys, would I need to insert a 2.5 mm sp plate into a conical bottom what procedure should I take? I'll send you the files to explain better.
the use you make, with excessive lightness, of the "spost-copy" function one day will make you life impossible.
Moreover to cut structural elements it is always better to use its specific function: shorten/expand.
