plate into a conical bottom insert
  • Thread starter Thread starter roccolaser
roccolaser
Hello to all boys, would I need to insert a 2.5 mm sp plate into a conical bottom what procedure should I take? I'll send you the files to explain better.
it would be nice that before asking for other aids
first you respond to the threads where you were given an answer.
the use you make, with excessive lightness, of the "spost-copy" function one day will make you life impossible.
Moreover to cut structural elements it is always better to use its specific function: shorten/expand.
a partial revolution is what you need.
