table and non-functional development
  • Thread starter Thread starter xxfast
xxfast
Hello, everyone.
Would someone know how to tell me why when I make the table in swx I can't view the sheet development?
on the part file everything works regularly.
:confused:
Hello, everyone.
:confused:
can't view is not sufficiently clear?but the flat repetition view inserted it? or in the dx tree do you see the flat repetition view?
You mean from here?
I think it's okay.View attachment 28519with the configurations are not yet very hardware :redface:
it would look exactly correct, feel close the table, deletes the configuration developed in the part and try to create it manually, the configuration developed and then insert it into the table.
Unfortunately all stations have been updated to swx 2012 and I can't try with 2011 and make you a practical example.
I'll try...
If you could explain to me how I should do it would be the top.
I'll try...
so the flight tries to see if you can solve this way.
or instead of deleting the configuration and doing it again you could:
activate development configuration
activate flattening
return to default configuration
Attached the modified video and file (in 2011)
Thank you, guys.
both solutions work, but re_ is the easiest.
Did I set the development configuration?
Thank you, guys.
generally the development configuration created by the table is already flattened. . .evidently something did not go as it had to if the development configuration was not flattened. . .
the important thing is that you found the solution :wink:
Okay, thank you.
As we have heard, you would tell me why when I get the sight flattened on the cartilage the fold lines always seem to me to be placed in bulk outside the cartilage : eek:
Okay, thank you.
probably is a problem related to the 0.0 service pack that would not even be installed. alternatively I think of the vga: is it certified?
Okay, thank you.
I suggest you enable the flag "preview", in the property manager, while placing the view.
sometimes it is "sufficient" (:mad:) select the view and display it shaded and immediately after returning to "visible lines" to make everything reappear in the right place.
I did this in beta 2013 with the hope that it will be taken in soderation.
I tried but it doesn't work.
I usually develop it from palette, in the menu to the right.
Anyway, if it's a sw problem, it's all right, so we're getting in. :biggrin:
Wait. .
seems that by selecting the development and then moving it up and down the screen, then release the mouse button by placing the view, everything works.
Wait. .
Yes, indeed... It is depressing but it is so.
did you try to do as I wrote before (habilitate the flag...)?
I have done several tests and I can assure you that with the active flag the view is correct, but these are things I fan me turn the boxes anyway.
I also reported in beta 2013 and hope it is considered.
I also have implemented the normal cut on multiple bodies in sheet metal... But this is a secret... :biggrin:
but if I insert the view from the palette as active the flag? :confused:
However, it's obvious, stay ahead...:finger:
