Exatem
better cold seen the climate....:tongue:It's not hot or cold.
Before answering, I did the tutorial to the point where you can't move on.Hey, guys.
Can you tell me what I'm wrong?
I can't make the surface from loft (see attachment) despite the preview seems to show the correct path.
That's rude! You don't write these things so raw and without a minimum of "savoire faire"!you are using the solid loft, for which you have to select a closed area.
you have selected two profiles so you have to use the surface loft, which you find in the surface controls.
? Um...That's rude! You don't write these things so raw and without a minimum of "savoire faire"!
If I were a moderator, I'd kick you in the back, you're lucky I'm not.
If you say so, Mr President, I have to do it:That's rude! You don't write these things so raw and without a minimum of "savoire faire"!
You didn't make a loft surface as indicated, you made a solid loft.thank you for speaking, perhaps with you there is a way to discuss peacefully without comments.
I'm in front of the tutorial,
(I'm on the page whose title is "surface-surface tracks with loft (continuation)", I made loft surfaces as indicated and saved.. Okay?
exact! but you can turn solids into surfaces with face clearing, then you will see that it will join you all, you will have a slightly different feature manager with the same final result.I read the moderators' response, here's my mistake, as you pointed out, not using surface commands from the beginning.
If we want to be taxable you should have noticed that the icons suggested in the help were not the ones you were using and you had to suspect:wink:. colors are very different just to distinguish them at first glance.but I said, asking patience because I am new, that there was no surface card and the loft command I found it under functions.
Who told me there was another card?
apart from all...marcof will have been ungold, but in its "rudi" ways besides never having offended and not having violated any forum rule, it gave you the answers you needed. it has pissed off the dose (without crossing the limit of the regulation for which I don't feel compelled to say anything) at the time when you're squeezed and instead of reasoning on its suggestions you're stubborn to say that the tutorial was wrong.then clicking on the command of the tutorial appeared to me the tab with the tools commands for mold and superfactory.
I will do it again from the beginning with the controls for surfaces.. That's why Marcof sees six and I 3...
from all this you express an opinion on both and its ways to participate in a forum.
two moderators have written to you that I am right and that the tutorial is correct, you are wrong and wrong exactly in the points I have too widely described.thank you for speaking, perhaps with you there is a way to discuss peacefully without comments.
they say that persevering is evil, and you certainly after the surfaces of your model are not six because you have not yet remade the first three features as surfaces. I explained why and the "percome", but you were obviously too intent to repeat that I had to carefully read the tutorial that didn't come to you (so according to you wrong. . . )I'm in front of the tutorial,
(I'm on the page whose title is "surface-surface tracks with loft (continuation)", I made loft surfaces as indicated and saved.. Okay? step to the next that it is called "superior of union - merge the basic entities" and invites me to join, you all the surfaces, but all, says, those that are inside "surface frames" that only 3 (And you're not and not adjacent).
They were enough and advanced my responses so that you could understand the error, and this attitude really does not honor you.I read the moderators' answer, here's my mistake,
Do you think that we're all in here with the nose ring and that we can't read what was written in previous posts?as you pointed out, not using surface commands from the beginning.
while I distracted between your requests because I carefully read the tutorials, I wrote this to you:(what could be said to me like you, with grace)
Wasn't he kind enough? I had to put this smile on us :36_3_8:and ask for your hand to follow the sigh?Marcof said:It's a surface tutorial, it tells you I'd use the surface controls, and you left using sweep and solid lofts. make three separate solid bodies, merge them with three loft surfaces and then claim to merge three separate surfaces. if you do everything with the surfaces the command merges, selecting all surface bodies (as specified with precision in the tutorial at point 3 of the page relative to that part), it works perfectly.
There's nothing to sell here. problems begin when it happens that someone fails to do something, it explains slowly where he is wrong, but he sustains to sword treats without a crumb of critical spirit that, for example, the tutorial does not come because and wrong. You know, to try to figure out where you were wrong, I had to look carefully at your screen shot at the beginning of the thread so I realized that you were wronging the first three features.but I said, asking patience because I am new, that there was no surface card and the loft command I found it under functions.
Now you also want us to tell you to open the surface commands toolbar while doing a tutorial on surfaces?Who told me there was another card?
When I told you, right away, that you had to use the surfaces you could have made some doubts and try, at least a little, to trust you.then clicking on the command of the tutorial appeared to me the tab with the tools commands for mold and superfactory.
It seems that you have arrived now because two moderators have written that the tutorial is correct. They also wrote you had to do as I told you. this of the six surfaces, to be selected from the surface body folder etc. is stuff written a nice piece back in the thread.I will do it again from the beginning with the controls for surfaces.. That's why Marcof sees six and I 3...
You can continue on these positions at odds, I follow you. Know that I have no intention of letting you twist your frittata. If you write certain things in public we clarify them in public and in public and well readable must remain (good connoitor few wordsfrom all this you express an opinion on both and its ways to participate in a forum.
I read only now your answer to panormus because I was dedicated to writing mine, which is not polemic and is not an addition but a clarification indispensable.Now, please, let's not add any further unnecessary controversy.
apart from everything...marcof will have been slightly garbed
marcof said:you are using the solid loft, for which you have to select a closed area.
Caxxo, you're right! I should have written it in French on parchment with the goose pen, after wearing a livery from lacché, red and edged in lace, with white silk socks and black paint shoes with bow and golden fibbione:smile:That's rude! You don't write these things so raw and without a minimum of "savoire faire"!
Marcof... You can't write such things!Caxxo, you're right! I should have written it in French on parchment with the goose pen, after wearing a livery from lacché, red and edged in lace, with white silk socks and black paint shoes with bow and golden fibbione:smile:
certainly it is not a drama, and in fact I took it into consideration, only that the error was yours and not the tutorial so I told you. Everything hereIf a tutorial had a mistake I don't see a drama at all, on the contrary I would consider it rather than criticize it, could it be no?
Are you kidding me? ? as it would be "not told me"Humility is to admit that there is no mistake in the tutorial (cut) because the error is upstream, but this has not been told, and it was not necessary to encapsulate on saying the tutorial is correct and wrong, but to make me understand the error.
Can't you read?marcof said:It's a surface tutorial, Tells you to use surface controls and you left using solid sweep and loft. make three separate solid bodies, merge them with three loft surfaces and then claim to merge three separate surfaces. if you do everything with the surfaces the command joins, selecting all surface bodies (as specified accurately in the tutorial at point 3 of the page relative to that part), works perfectly.
You couldn't think it was correct when I wrote you what is reported in red above, so of the three: or you don't read what you write or don't understand or ignore it.I couldn't be insistent if the regress I thought was correct and so I didn't see the surfaces, let's face this.
I don't "inspire" me. I intervene trying to make my contribution. I then add that the ways, in my posts I decide them according to what they answer me, do a reasonAnyway, it's closed here for me, I hope my friend marcof doesn't get into my future posts if not with the necessary ways.
Tell me I read bad and I didn't understand anything, because now my head turns.. .
and the fact that you suggested that I should use the solid loft It didn't make me clear that from the beginning I had to use them.
I agree! Just that you had me consume 150 neurons to follow the whole speech and my age every neuron counts!...
with this I would really like the "polemic" to be closed! we go ahead with work and do well sti benedetti tutorials.
but also with the lace handkerchief held in the palm though! :smile:Caxxo, you're right! I should have written it in French on parchment with the goose pen, after wearing a livery from lacché, red and edged in lace, with white silk socks and black paint shoes with bow and golden fibbione:smile:
You have a wrong way of ports when you explain....
I wrote this to you in post #16:
