COUPE
After installing autocad 2011, when I have to go to activate the program, when I click on the autocad icon this opens and then close a few seconds later!... what can I do? ?
try to see if the problem is thisAfter installing autocad 2011, when I have to go to activate the program, when I click on the autocad icon this opens and then close a few seconds later!... what can I do? ?
if I recommended you malwarebytes full there will be a reason, unless you used to scan what I recommended then the problem is to be discovered.I did a full scan of the system but there is no virus or trojan.. what can I do?
then the problem to search probably is strange, so since you are student and you can have free license, as from advice of tristan installs the 2013 versionI used malwarebytes as my advice!
install the service pack 1.1 for autocad 2013.I tried to install autocad 2013 the problem is that the top left bar is transparent and the underlying bar with all the applications crashes..
the active slide bars in the options, display board (incertainly I do not see among other things the slightest utility, matter of habit. . . )...Finally missing the side scroll bar!
ahh, you mean the toolbar "fast access".the requirements have them.. regarding the ''barra'' would be the part next to the autocad on the top left.
