autocad activation problems 2011
  • Thread starter Thread starter COUPE
COUPE
After installing autocad 2011, when I have to go to activate the program, when I click on the autocad icon this opens and then close a few seconds later!... what can I do? ?
I did a full scan of the system but there is no virus or trojan.. what can I do?
if I recommended you malwarebytes full there will be a reason, unless you used to scan what I recommended then the problem is to be discovered.
I tried to install autocad 2013 the problem is that the bar on the top left is transparent and the underlying bar with all the applications crashes and finally missing the side scroll bar!
I tried to install autocad 2013 the problem is that the top left bar is transparent and the underlying bar with all the applications crashes..
install the service pack 1.1 for autocad 2013.
...Finally missing the side scroll bar!
the active slide bars in the options, display board (incertainly I do not see among other things the slightest utility, matter of habit. . . )
What is the "barra on the top left"? but does your pc have at least the minimum hardware requirements for autocad?
the requirements have them.. regarding the ''barra'' would be the part next to the autocad on the top left.
ahh, you mean the toolbar "fast access".
but the service pack for the 2013 I recommended you installed it?
