flaviobrio88
between the surfaces making the zebras move you should see constant "beams":http://www.screencast.com/t/fo7cgmsf
Hey, what do you mean, "Fasce"? ?between the surfaces making the zebras move you should see constant "beams":http://www.screencast.com/t/fo7cgmsf
refers to zebra strips, typically you have three cases:Hey, what do you mean, "Fasce"? ?
http://www.cad3d.it/forum1/showpost.php?p=293879&postcount=12Why do you say that you don't know anything while you're here to talk about it as an expert?refers to zebra strips, typically you have three cases:
1) between a surface and an adjacent stripes are discontinuous (i.e. steps from white to black): means that the two surfaces are connected to live edge.
2) between a surface and an adjacent one see an sudden variation of slope of the strips: means that the two surfaces are in continuous c1 (i.e. a connection between a plane and a cylinder or between two cylinders, typically the case of the constant beam connection)
3) between a surface and the adjacent strips are gently collected: means that the two surfaces are in continuous c2 (i.e. parabolic functions). Typically, stylose designs use c2 continuity, but I don't know if this has anything to do with the aerodynamic functionality of an object.
I was wondering about the importance of the constant rope connection, which has nothing to do with the curvature continuity.http://www.cad3d.it/forum1/showpost.php?p=293879&postcount=12Why do you say that you don't know anything while you're here to talk about it as an expert?
I believe that the exchange of views is legible, while the choice of certain verbal forms leaves a lot to be desired.How come you say you don't know anything while here You let me to talk about it as an expert?
No, it's not worth it.I believe that the exchange of views is legible, while the choice of certain verbal forms leaves a lot to be desired.
When they are aimed at hunters, steps, given its enviable pacacity, but I want to point out that using certain terms with some people exposes users, moderators, post, threads, as well as the whole forum to an escalation of insults, warnings, bans, and especially bitter blood.
I wonder, is it worth it?
I hope for you too!I think I clarified in mp with a hunter.
Since you are very competent, would you also be generous with the community in explaining how aeronautical surfaces should be made (see that my not only wings those mails) and how to analyze them?
Hey, baby. .Waiting for rs4 lumens I place some image that can help you explain to me, if you can please, how to interpret the goodness of the surface made and where/as possibly I could correct/improvide.
