separate material - cutting
  • Thread starter Thread starter roccolaser
Thank you 1000.
even if for the work I do I will use little these functions, but you have been very helpful.
The only thing I've noticed is that you have to be careful how to select the groups of the structural elements, otherwise you can find them in the table all mixed between numbering and corresponding length.
I did a test...View attachment 30227:finger:
You want advice?
considering that the work you carry out, on these elements, is relatively simple, I would tell you to learn precisely because you are not "under pressure".
structural elements are light and quick to achieve.
Sure, a profile library is insepensable, but they are also located around this forum.
Moreover, once a property is given, which can be the name of a profile, measurements or anything else, this data will automatically insert you into the cutting tables.
I attach a file, imagine what it's like to draw it in a traditional way. . .
http://www.mediafire.com/?yjhqcdkvrftip2k
in the table you can click and drag the table files and reorder them as you like. the numbering of the ball will be updated accordingly.
for the rest the tables work more or less like those of excel; click with the right (always clik right in swx, I will never stop repeating it) and look at all the options.
I don't understand...
if I click on the left button on the table I do not see any option to order. If you can post an image like that, I understand.
However I meant that if you have 2 identical profiles, of the same length, it can happen that he assigns 2 different article numbers.
I can manage to do this by selecting structural elements groups in a certain way.
sampom wrote: clikka and drag... test... :smile:
good morning to all, you might also think of inserting a distinct material(in place of the cutting)dissolve the table(dx key on the structural element "dissolve") and you will find the sum of the various lengths in automatic (allego modified files.
I hope it's all clear. Good day
Maybe I'm tough, but I can't move anything.
is it not that I have to uncheck the automatic function in the part, in the item list?
However my problem is to understand why it can happen that assigns two different article numbers to 2 parts that have the same length.
1-from the table, all left, drag a row and you will see that it will move.
at the same time the number of the ball is updated.
Now I can't but I'll put you a little video.
2-if he assigned you another number voul say that the piece is not identical, you want for a different angle, you want for a hole or whatever. Trust me.
2- if he assigned you another number voul say that the piece is not identical, you want for a different angle, you want for a hole or whatever. Trust me.[/QUOTE]That's what I wanted to hear.
Then I got it right.
for the video whenever you want is always useful.
is that I have to uncheck the function Automatic automatic in part, in the list of elements?
Sure, that's for sure. of the rest as he showed you mike in the image posted yesterday: Automatic automatic and then update.
and updates often, whenever you add/mode elements and/or use functions; you notice from the change of icon in the tree.
to move the rows by clicking everything to the left you realize that the cursor becomes an arrow "to team"; indicates that you can change your order.
I am creating a distinct table of materials with detailed cutting distinct: Is there a way to make sure that the automatic updating of the items list in the various parts is regularly carried out? sometimes I find myself at the table of the pallonate elements with *, so I open the part and aggiorno list elements, but having to make it x dozens of parts is a bit risky of forgetfulness (as well as boring)... thanks for the answers
