block rhino control points
  • Thread starter Thread starter fiddleman
fiddleman
how can I edit checkpoints without moving anywhere (in the other 3 windows)?
I took off all the snaps and tried the tab button but nothing.
control points exist in space, so if places move them naturally in all views, it is normal. . .
keep in mind that if you carry a checkpoint in a view, the shift will only be in the two axes of the active "pianoc" in that view (in other words: the point moves on a plane parallel to that of the "grille" that is seen in that view); this should help you understand how logical the drag works
(of course we have talked about dragging control points, but the same applies to rqualsiasi object)
If that wasn't your problem... Pretend I didn't answer you and try to spit out!
That was the problem. But is there no way to change the point out of the pianoc? :confused:
If I go dragging the same point into one view and then into another, and then in the other, it's never where I want it to be placed... :frown:
Thanks anyway for your help.
you can select the point and apply the command Moveuvn**; you have selective control for every single point:finger:
** you can find it in the menu transform/muovi uvn
