fiddleman
how can I edit checkpoints without moving anywhere (in the other 3 windows)?
I took off all the snaps and tried the tab button but nothing.
Hi.That was the problem. But is there no way to change the point out of the pianoc?
If I go dragging the same point into one view and then into another, and then in the other, it's never where I want it to be placed... :frown:
Thanks anyway for your help.
Thank you:Hi.
you can select the point and apply the command Moveuvn**; you have selective control for every single point:finger:
** you can find it in the menu transform/muovi uvn
activates the planar snap and the control point will move only on the active plane and then in only one axisThank you:
