What do you mean my foreskin is smaller?Bye!
I would also represent the "smusso" that indicates the end of the incomplete thread section (in yellow in the attached image).
lack the positioning odds of the hole.
the foreskin for mating m5 is ø4,2: to the eye, your is a little smaller. try to comply with the measures, it is important. In this way even the bevels at the beginning and at the end of the thread will be more "suited"! !
means that the diameter of hazel does not seem correct for a hole m5!What do you mean my foreskin is smaller?
.... maintain the positioning quotas of the hole.... .
and I trusted you...:biggrin:I quote all others and add that you should also insert the hole location quotas.
for example beat the bottom left end of the plate and from there you will find the components of the x and y distance of the hole center.
sì, immediately immediatelyUnless you want to do the prehort with a nail.:biggrin:Okay.
I'll correct the tip right now. thanks to all
Yeah, I hope that guy's okay. :biggrin:...as did that boy... That's fine, isn't it?
You're right, I haven't seen your second line!:tongue::finger:and I trusted you...:biggrin:
I'm kidding. :wink:
