revit versione lt
preben
Good day, someone knows the version program revit lt ? Would I like to understand what was "already"? .... there are some basic commands to me... .
the "things" that does not:
workset: project sharing among more users
rendering: rendering engine is not present locally, you use cloud rendering service (autodesk 360)
conceptual masses and masses
local components, i’model-in-place’’
energy analysis/structural analysis
loading third-party applications; is closed as autocad lt
cloud management of points
Axioms
Axioms
Is that right, but going into detail, like "travel system"?... "decalcomania"? as I use it seems too "light"!!!! I hope I'm wrong!
What do you expect? It costs less than a third of the full version, to me it seems little light instead! and anyway lt is not for "light" but it is the acronym of limited technology.
I meant light for my wallet ... However I confirm that the beam system is not there............... is there any proposal for structural tiles? ? ?
the differences there are, the price difference between the two versions, must be "justified" by the difference of content that on the one hand translates into "macro-contained" or renderin, workset, model-in-place etc, on the other in individual features and/or automatisms like the beam system. There are also others in detail on this page http://usa.autodesk.com/adsk/servlet/pc/compare/index?siteid=123112&id=20336963for structural tiles, I imagine you refer to the shaving to fill a roof with an object that simulates the tiles is and remains an escamotage... I don't think there is a solution. if not the manual insertion of the beam / tile.
That's right! but to explain better: I think the difference between the two versions is very comprehensible, but removing individual features gives me the idea of "moving" some commands. (to make the idea is as if with the rvt lt I could not do the copy command with multiples..... did I make the idea? )
for me, it's very clear. if you pay less, you receive less. If you want more, you pay more. so simple.
how not to share it!!! I'm weird-straight.
I can add that for work, I use daily revit, both the lt version and the full version.
My judgment on the lt version is more than positive, I think it is a great solution, which is addressed to those who may normally work with autocad lt. the cost is low and what you need is, it is designed in 3d, with parametric elements and in bim environment. as evolution from the line-arch-circle... I'd say it's not cheap. disquisire on the command that is missing is talking about goat wool
