preben
Good day, someone knows the version program revit lt ? Would I like to understand what was "already"? .... there are some basic commands to me... .
Is that right, but going into detail, like "travel system"?... "decalcomania"? as I use it seems too "light"!!!! I hope I'm wrong!the "things" that does not:
workset: project sharing among more users
rendering: rendering engine is not present locally, you use cloud rendering service (autodesk 360)
conceptual masses and masses
local components, i’model-in-place’’
energy analysis/structural analysis
loading third-party applications; is closed as autocad lt
cloud management of points
Axioms
What do you expect? It costs less than a third of the full version, to me it seems little light instead! and anyway lt is not for "light" but it is the acronym of limited technology.as I use it seems too "light"!!!! I hope I'm wrong!
That's right! but to explain better: I think the difference between the two versions is very comprehensible, but removing individual features gives me the idea of "moving" some commands. (to make the idea is as if with the rvt lt I could not do the copy command with multiples..... did I make the idea? )the differences there are, the price difference between the two versions, must be "justified" by the difference of content that on the one hand translates into "macro-contained" or renderin, workset, model-in-place etc, on the other in individual features and/or automatisms like the beam system. There are also others in detail on this page http://usa.autodesk.com/adsk/servlet/pc/compare/index?siteid=123112&id=20336963for structural tiles, I imagine you refer to the shaving to fill a roof with an object that simulates the tiles is and remains an escamotage... I don't think there is a solution. if not the manual insertion of the beam / tile.
how not to share it!!! I'm weird-straight.for me, it's very clear. if you pay less, you receive less. If you want more, you pay more. so simple.
Today I have arrived the package with the suite autocad lt + revit lt ....... show! !I think you should wait for the release of 2014
