stirare le quote
  • Thread starter Thread starter giacomel
giacomel
I can't iron quotas
stand using autocad mechanical 2005
on window 7
I'm told they're perfectly interfaceable
Can someone help me?
cristina
What does it mean to iron quotas? if you iron geometry and in the selection you also take the odds these follow the geometry. be careful to select from right to left otherwise the iron does not work properly.
if you only need to hook the quota from one point to another, simply select the grip of the extension line and place it where you want (always the snaps activated allow it)
Thank you for answering me, as I imagined, I've explained, try again. .
you see a series of odds aligned with each other horizontally
I want to move them up to iron them at the same time with window (from right to left)
all quotas move up but they remain attached to the points to which they were referred
if instead I want to iron to the right of a figure to which a quota is linked
I iron myself the figure geom. but nn the quota line that should be updated increasing its value
I hope I've been clearer
Is he just doing it on that file?
Could be that the file you try to edit is native to classic autocad, not mechanical?
sometimes I had problems in this sense; Now I do not remember if there was also the failure to iron the quotas, but surely gave me problems with the grips of this last and it was not a matter of entity on different position z. I always solved by copying everything on a new design native to mechanical.
do this verification
If you change a listed item, the quota will automatically update if the share is associated. select the quota and check the properties if the associative property is yes.
If it wasn't, you have to open the options, user preferences tab (if I don't remember bad) and snacks "make new membership odds".
If you want, you can make odds associated with the dimriassocia command.
I find the most harmful associative quotas of the problems that should solve.
If you have an isolated rectangle, they work well, if you have anything connected to the extremes when you go to change the object often happens randomly.
It works so well the dear old stretch, why dannarsi con le associative?
partly agree with you.
for membership fees to work, you must carefully select the points of objects; if the selection is not done correctly, just a small, innocent change and boom!!!
One way they have it, you have to be very careful in use. I do not think it is an indispensable function.
Yes, attention in selection is a decisive factor, I agree. but unfortunately not enough.
The problem is, almost always in the drawings there are common points to certain entities.
Let's make a banal example. the edge of a pillar coincident with the line of a beam edge (as well as so many others.. the center of 2 concentric circles representing the section of a pipe, the edge of a window in a wall, the axis of a steel column etc etc.).
you should know a priori what element you will change later, to make the association work properly. but glass balls still have to invent them, associates or not:wink:
It's the usual autocad problem that, ahime, it's a "ignorant" software. in revit, for example, I do not ask myself the question because the quota is associated with a "real" object and not to a line or a vattelapesca circle
