Exatem
the piston object of the president's photographic service, now makes beautiful show of itself on the bedside table of the same and receives the good night basin. . .
It's been years since the office...the piston object of the president's photographic service, now makes beautiful show of itself on the bedside table of the same and receives the good night basin. . .
http://www.cad3d.it/forum1/showthread.php?36415-3d_freeviewer&p=307138&viewfull=1#post307138I'm not able to say if "technically" is valid or not, but at least "I see" quickly and easily! :smile:I recommend we complete the checks and finishings before we move on.
Please put a wrml version for each step so even those who do not have a cad can recognize the pieces and work to keep the archive and excell sheet in order.
Alternatively you could put a jpg with the same code always for classification purposes (which you could also "connect" with a hyperlink to the electronic sheet.
On the contrary, better the single shovel that then I have to model her attack on the hub.In fact, does anyone have a three-wheel propeller already ready? :tongue:
finished the planche vii - réducteur 12/17 regarding the only reducer (only some details remain for the version "avec distributeur a gaz")
now attacks the hub of the propeller.
p.s. the tag indicating the direction of rotation I did not like and I did it again but after making the renders.
Top level! I feel like I smell the oil. public now.a section with the direction of rotation modified
Forget the propeller, let's go ahead with the compressor...On the contrary, better the single shovel that then I have to model her attack on the hub.
It's so loud! I loaded marcof's axieme and I also made the render in "men that don't say"!http://www.cad3d.it/forum1/showthread.php?36415-3d_freeviewer&p=307138&viewfull=1#post307138I'm not able to say if "technically" is valid or not, but at least "I see" quickly and easily! :smile:
:4425:terminata la planche vii - reducing 12/17 View attachment 32572View attachment 32573
:4425:
When you load the step on gd I put it in the general axieme so er_president has a lot of fun and, you've ever seen, he also puts himself to make some renders. :smile:
No no no:smile:View attachment 32579 I sent it to sandra, which then should put it on gd.
put on gd.No no no:smile:
everyone must upload their own... otherwise we no longer know who the author "culpable":wink: of the work done!! :smile:
I asked but did not receive reply eoptai for the most ostico (sa... I have to learn how to use these modern parametric systems and it is when the fight gets tough that...)So let's do what we want...
Forget the propeller, let's move on with the compressor. . .
Meanwhile the hub is in working. . .
the answers were there, but "we" pretend not to hear...I asked but did not receive reply eoptai for the most ostico (sa... I have to learn how to use these modern parametric systems and it is when the fight gets tough that...)
Anyway, I get it, but you have to do all this good man alone? !the answers were there, but "we" pretend not to hear...
p.s.: I will have to be more "persuasive." . .
Ohhh!Anyway, I get it, but you have to do all this good man alone? !
Where did the rest of the army go? ! !
Should I come get you?
