gnome-rhone 14m mars
  • Thread starter Thread starter Er Presidente
the piston object of the president's photographic service, now makes beautiful show of itself on the bedside table of the same and receives the good night basin. . .
I recommend we complete the checks and finishings before we move on.
Please put a wrml version for each step so even those who do not have a cad can recognize the pieces and work to keep the archive and excell sheet in order.
Alternatively you could put a jpg with the same code always for classification purposes (which you could also "connect" with a hyperlink to the electronic sheet.
http://www.cad3d.it/forum1/showthread.php?36415-3d_freeviewer&p=307138&viewfull=1#post307138I'm not able to say if "technically" is valid or not, but at least "I see" quickly and easily! :smile:
finished the planche vii - réducteur 12/17 regarding the only reducer (only some details remain for the version "avec distributeur a gaz")
now attacks the hub of the propeller.
In fact, does anyone have a three-wheel propeller already ready? :tongue:
p.s. the tag indicating the direction of rotation I did not like and I did it again but after making the renders.untitled.125.webpuntitled.124.webp
a section with the direction of rotation modified
Top level! I feel like I smell the oil. public now.
:cool:
:4425:
When you load the step on gd I put it in the general axieme so er_president has a lot of fun and, you've ever seen, he also puts himself to make some renders. :smile:
stellainchino.gif Thank you.
I sent it to sandra, which then should put it on gd.
mancha the part vii_341 (the one indicated as thick 8mm) to be interposed between the part ii_11 (the one shaped by max to understand us) and the group reducer.
Keep in mind that the propeller shaft will have to be "revisited" as soon as I have prepared the door hub.
On the contrary, better the single shovel that then I have to model her attack on the hub.
Forget the propeller, let's move on with the compressor. . .
Meanwhile the hub is in working. . .
So let's do what we want...
:cool:
I asked but did not receive reply eoptai for the most ostico (sa... I have to learn how to use these modern parametric systems and it is when the fight gets tough that...)
the answers were there, but "we" pretend not to hear...:cool:
p.s.: I will have to be more "persuasive." . .
:eek:
Anyway, I get it, but you have to do all this good man alone? !
Where did the rest of the army go? ! !
Should I come get you?
:mad:
:cool:
Ohhh!
Finally.
There are always times when the commander's place is not back with his major state but ahead with the trump.
p.s. is not insubordination, I started the planche vii and I wanted to finish her commander.
Ohhh!
Finally.
