IlNanni
if I impose a value on element size and then I want to return to the value of defualt as I do? Obviously without having to reconstruct the analysis from scratch...
I changed the title (mesh not mash).
if you have done the analysis and change the value it is obvious that the analysis must be done again! analysis depends on mesh.
if you want to return to the default value you have to delete or suppress the emission size, reset the mesh (I don't remember how you do it) and remake the mesh
I work in wb 14.5. trying to make clear generated data then cmq reappreciate the mash value previously set and not the default element size.That's right. .
If you don't realize mesh, how do you think you can launch the analysis? !
a "brutal" way to return to the default value of the Element size is to clean the mesh (areas, volumes) save the "geometria". close ansys.
reopen ansys and work!
Forgive me, but I still don't understand.the volaff procedure also works for the wb version 14.
first delete the item size, then right button on the mesh, clear (I don't remember what it writes in the menu, but it removes results, mesh, analysis, etc.) and then remake the mesh and you will see that it works.
I tried it 30 minutes ago and it works.
ps. but do you have the automatic concealer? mesh, not mash!!![]()
