special toothed wheel
  • Thread starter Thread starter Rossi Rodolfo
Rossi Rodolfo
Hello, everyone.
I can't draw the teeth of a toothed wheel, having no dedicated additional package. the main problem is that the customer asks me a wheel with a pressure angle of 30°, which not even from the sites like "traceparts" I found nothing with this characteristic.
The wheel I need must be:
module=3
pressure angle30°°
Greetings, Rodolfo.
but for what reason you have to draw your teeth, the builder is enough of the teeth and then he thinks about making the gear as you ask.
Hello, everyone.
module=3
pressure angle30°°
Greetings, Rodolfo.
normally it is true. but this wheel I have to build it in sheet metal, so the thief wants the exact profile of the wheel to perform nesting.
Thanks, bye.
Thanks, bye.
try with this macro, but before sending it to the supplier verify that the profile is really as you need and not an approximation of circle arches.
I found in my archive this "program" that creates a dxf 2d. It approximates the evolution in segments, and it seems to me it is possible to define also the fineness of these segments, to approach more 'the evolved theoretical.
Sorry, I solved. just read the .odc file contained inside!
Thank you so much!
