Granato
Hello, everyone!
I have a problem with the 2014 autocad:
with previous versions I was used to design in the model and then to scare using the paper space where I created one or more windows.
Now I don't understand how to create the windows in the layout space as, as you can see from the images I have attached, if I'm in the layout space itself, and I go to the tab "view", the program deactivates the group "model windows" and so I can't create a window at will (among other things I don't understand why this group calls it "model windows" when we really are in the layout and not model space).
Conversely, as you can always see from the other image attached, if I am in the model space and go into the tab "view", the group "windows model" this time is active and you have the opportunity to create the windows at will even if I don't know what we do since we are in the model and not in the layout.
Thank you very much
Thank you very much
