andrea_lovat
Good evening to all,
I write to you for a problem that I found in linking an excel file to a set. I explain better: inside a folder in my pc I created a set of components and assemblies connected to an excel sheet. being a project of a complex machine I divided the various parts and subaxis of the machine into various subfolders; I finally created a general set in the initial folder. always here I created my beautiful excel file that manages all the components of the machine. to connect the parameters I always used the "connect" function. but we come to the point: until I work in this folder there are no problems, if I change a quota also changes the assembling but if I cover all the catella from another part, to have two different designs, the drawing does not change even if I see that the link to the excel sheet is correct....it always keeps the quotas of the file of origin and does not update a bat. What can that be?
I add that the folder where I created all the design is a project folder.
thanks in advance
Andrea
thanks in advance
Andrea
