Cristallo
a problem (maybe) banal, to which I cannot find solution.
I have a dwg, in which by desire of the client, I inserted a large number of hyperlinks to photos.
here everything regular, pass on the hyperlink, you will find the connection simboletto, if you click with ctrl+click you will open the photo.
because I think it is very uncomfortable for the client to open autocad to view the links (and especially because then there are various layouts and hyperlinks do not extend to the layout views) I thought to produce a pdf that contained them.
tried in all ways, with acrobat full, with pdf creator plus (the trial), with dwg to pdf.
all perfect pdf but without the shadow of hyperlinks.
Has anyone ever found a solution?
