eugenesis
. So, guys, we're going to order.
ilogic is used to create automatisms of use by managing the bees of inventor with its programming language ,
more or less as it was done in the night of the times with the old autocad autolisp.
you can do (if you are able to..) even wonderful things!
the thing that is asked is to have practically the possibility to change to pleasure the content of a whole without changing it
the container, this also in real management becomes difficult; the alternatives could be, like, the use of the assemblies,
but here at the end we create different assemblies (and perhaps the game is not worth the candle ..) ; I find the macchinosi iassembly in their construction .. at the end perhaps I first mount several assemblies untied .. I lose however connection between them
which gives me the opportunity to replace a model with another, mind with ilogic I can also create a configuration
not already in the table. .
the other solution would be to take a shortcut (burnt to say, ethically incorrect .. but effective and simple. . )
ie go edit taroccando a manazza the table .. maybe putting an asterisk + a note somewhere to mò of reminder for future management ..
I know that sometimes you have to adapt to take shortcuts .. but in life there is worse ..sperando meanwhile
that our friends of portland perhaps implement some new possibilities!!
on this page :http://forums.autodesk.com/t5/inventor-ideastation/idb-p/v1232never go to read-write??
while as regards the difference between view rappr.ne and detail level,
the first manages visibility, colors, frames etc. so we can alleviate-appear the work of
video card with consequences on table 2d.
the level of detail works instead at the level of loading-downloading data in memory therefore has effects on management
of ram by suppression-replacements etc.
at the end both things serve as basic tools for the proper management of large assemblies (simplification etc.)
