TECNOMODEL
I would need a clarification about the sketches in inventor.
I have a detail with a hole that I want to open like asola to the outside.
I project the edge of the hole and the outer one, I build 2 lines with appropriate constraints and coincide with the geometries projected.
At this point, however, the projected geometries cannot divide them into a part of construction and the remaining to close my profile.
I can not even use the sketch to make a cut extrusion because the profile is not closed.
Do I have to create 2 arches and bind them to projected geometry?
seems strange as a method, leads to a lot of lines many of which overlap
I attach an image if I have not been clear
