rf.infissi@libero.it
I would like to ask if someone found a quick enough way to serialize a frame generator element without raising the level component, which would cause loss of frame generator facilitation.
Then I don't think you can do whatever you want. I usually keep away from the design board because I am then tied to its commands.Thank you for having responded
I know the command reuses but what I meant and to create a series like the series of solids, now I do it simply by raising level the component is transformed into solid serializes normally though if then I need the command size extends etc. of the frame generator I can no longer use it since it is a solid.
