serialize frame element
  • Thread starter Thread starter rf.infissi@libero.it
I would like to ask if someone found a quick enough way to serialize a frame generator element without raising the level component, which would cause loss of frame generator facilitation.
hi, I don't know what version you have, but with 2015 you can create the path and. After ever insert the first item, use the command reuses and select all the positions where you want to insert the same item. in this case a subfolder is created on the browser that contains all the reused elements.
Thank you for having responded
I know the command reuses but what I meant and to create a series like the series of solids, now I do it simply by raising level the component is transformed into solid serializes normally though if then I need the command size extends etc. of the frame generator I can no longer use it since it is a solid.
Then I don't think you can do whatever you want. I usually keep away from the design board because I am then tied to its commands.
I imagined it anyway I found some help lcopy even if what I wanted not on can do, thank you very kind
