Volume for subframes
  • Thread starter Thread starter Kattivo83
Kattivo83
Good morning to all, I will shortly write a short presentation and then I begin to apologize for such a gap.
said that, does anyone have any suggestions on how to make the mold for this element? I need a smart system to free the hooks (if it is useful to have them tilted orthogonally I can become 4).
Unfortunately until now I have designed only molds without subsquadri, so they are zero with design solutions.
attentive to those teeth as the rounded shape gives you a section hardly controllable as stiffness.
to remove the subframe simply make a hole from above.
Yes, I know very well about the circular section, the image is a draft designed in 15 seconds.
What do you mean, "do a hole upstairs"? I need to know how to extract hooks
Yes, I can't post more explanatory images now because I'm going to the dentist... maybe tonight.
Thank you very much. Obviously as soon as I finish and I can send you the 3d of the mold.... I always like to compare.
If you do not want to make holes there are special extractors that while opening have a side shift and free the tooth.
were created specifically for these situations.
also because as you set it the piece remains on the side that, I imagine, is the fix.
How do you extract it? Could you turn it around, but can you put the extractors that way?
the design of the piece is free, so I can also use the holes system. As for extractors, for example, you refer to ees-flex pedrotti, right?
more or less this
but the solution of the holes of the ceschi friend1959
is fast convenient and economical
Thank you very much
hi shiren, I press that I am the one to thank you.... anyway, I repeat, actually the solution of the holes suits me more than well, considering that: 1-is economic - 2- is within my reach - 3-I can make the mold in ergal without inserting nitrite elements to preserve the scoring - 4- is not that my workshop is properly equipped to work extractors of the genus
I agree with others, if you have the possibility of the solution of baskets is the best.
there are also of the cumsa, dme, hasco, however depends also on the width and height of the tooth discharge, be careful however that a tooth made so there is the danger that does not shove enough to hook being on a bombing.
hi playmb and thank you for your contribution. the tooth shoulder will be straight to facilitate the bending, that is a draft I made in 15 seconds to make idea.
Anyway, I take advantage of it, is there someone so kind that he would want to control my fixed and mobile step to verify that he didn't shit?
If you want a look, I can give it to him, I don't know if I can do it right now.
Thank you very much. At the moment I still have to finish, so if he talks about it in a few days, I'll catch you as soon as I'm ready.
And so?
first opening remove the male punch making the hole
second free cover plate
spin on the disc that remained on the intermediate plate and making the teeth sting inside (as they have to work ) free the piece
for mamobono: I don't think I understand your system....:frown:
for all the willing: how do you send the steps? are ready!!:finger:
