nx10 - official topic
  • Thread starter Thread starter The_Matrix
version 10 is out of half a second and ask if you can install it on a particular know. are not questions to ask in a forum according to me but directly to gtac.
if I knew that he had been out a few seconds ago I would not have written I sent an email to siemens and wait for news even if on their forum I had read that he had gone out in October 2014.:smile:
then as they say " ask is lawful to answer courtesy " no? :
or beautiful,
I started using the 10 and I noticed that you do not see the whole expressions. They are replaced by intermediate parameters, grouped, blocked and hidden
what's new is about it, but only by saying that from now on they are blocked.
I asked lumens to the help and they answer me that it is just so (of course in a much more articulated and kind way).
How come this change?
I'm veiled!
Following the installation of the patch nx10.0.1.mp03 the delete command, both on assembly element and on part navigator element (in summary, deleting something) became lentiiiisssssimo .
I confirm the cancellation for an object or part and wait 20/30 seconds to read a confirmation window!! I have already given confirmation!!
copy this behavior?
subject: certification of nx 10 on windows 10
affected software: nx 10.0.3
associated pr number(s): n/a
scope: windows 10 professional and enterprise
revision: n/a
this is to announce the certification of nx10.0.3 on windows 10 professional and enterprise. the certification process consists of testing the installation and operation of nx on several windows 10 systems by running the full nx qa suite of tests to verify operation and detect any anomalies. several minor issues were detected and documented in the following section. it is the position of siemens plm software that these minor issues will not affect the use and performance of nx on windows 10
and that this new os is fully certified and supported for customer use.
known issues:
1. license server installation. the installation of the license server fails on windows 10 if java 8 u60 is used, which was the latest java version available from oracle. the install requires java 8 u45 or java 8 u51 to operate correctly which can be downloaded from the archives on the oracle download site. we are investigating newer java releases and working with flexera for an updated install that does not exhibit this problem.
2. the windows 10 system theme does not display the siemens name in the nx title bar. the solution is to not use the system theme. nx development is investigating.
3. minor nx start-up performance degradation and resource consumption. it appears there is slightly more overhead associated with windows 10 that affects the initial load of nx. in addition, additional memory is consumed by nx when compared to windows 7. however, operational performance does not appear to be affected and in some cases is faster on windows 10 when compared to windows 7. (e.g. assembly save operation)
per our standard support policy, once an os is certified it will remain certified and supported for new releases of nx until an end of life statement is released. this means that nx11 will be supported on windows 10 when released.
that two m....oni with this java!
