confused with what? If you tell me you've been able to join, I believe you and I tell you I've already suggested it.You must be with me
boh... stai parlando arabo per me. . .But you realize a person has to look at all the dwg to see where the stuff is? I had put a red circle or something. and already this makes the bales turn.. .
succeeding to find the silhouette I see that they are blocks, that one is a block inside a block and three only blocks of first level, that exploding the blocks I find unified entities, that you did not eliminate the ages indicated by the red arrow in post #23 but those that you said you would join and that they would have formed a kind of omega.
Why make blocks if you turn, or should you do it, polylinear the shape?
is practicing the same as the other time. also the shape of which is spoken by #30 post It's the same.here I also attached the .dwg with the changes already madeView attachment 42260
I agree. But I'm afraid it's one of those "heavy chetes" that when patience loses it, they make a slaughter, so I'm in selfstudent, I'd put myself in line as soon as possible:Oh, Mass.
Seriously. . .
I know about patient people, but I think you're gonna get over them.
