cam integrato
  • Thread starter Thread starter TECNOMODEL
I got the cam.
only that this, even with its limits is simpler to use, is parametric, and it is free, I do not have to pay double sub (hypermill +inv).
If it seems short to you...
I agree with tarkus, I did not see version 3 or 5 axes but I must say that integration is good and it is also simple to use.
Moreover it is easily customizable for the machine on which you use, and it is not little.
It is still uncommon because it is a novelty and the same autodesk dealers do not know it, with the desire to save that there is in the companies I would not wonder if it took foot.
Okay, I give up.
I said I don't understand anything about cam.
I still have the idea of leaving him here, now I see if I put the matter to Sandra.
but it is certainly good anyway to leave it here, it was just not to bother other users who do not use this cam
I did a test with contour 2d, from there you can select a edge if in the model you do not have the bevel and set depth of the bevel and offset to use on the tool.
in that way you can work on the side of the tool at 45° and not always on the initial edge.
I did this myself, but if I tell him that I am using a tool for bevels, he gets very angry and tells me that it is
a processing not possible with that type of tool... .
It makes me do it. the tool I took from the existing library, by type/chamfer thousand
I reconnect to this old woman for this problem:
When I go to create the nc file with the post processor, I don't see the editor.
I tell him the name and directory of the file, I give theok and the thing ends there.
He doesn't show me what he created.
I thought that no post would process, but opening the folder I find the file created.
I just think it's a setup problem.
I just didn't find where to get the right tick off.
Any ideas?
greetings to all
I think we should always write in this discussion.
Anyway, greetings, first post and first question of the year:
I installed inventor+hsm on a new work station, all right, I opened files with cam paths made with hsm on old work station, edited and saved, okay all right... or almost.
both on old files and on new files, there are no more custom libraries I had on the old machine.
who knows where the tool library file is saved?, to try to replace it on the new machine?
I answer myself:redface:
hsm creates a directory "my library" directly in documents, just import it with "tool library"
sorry if I go to exhume this 3d, I would be interested to try the hsm and I wanted to understand how to download it and if it is understood in the license because at the link you have indicated ask all the data for registration. then, its operation depends on the version of inventor installed, I have 2014 (2015 licensed but never installed), or is it a program itself?
only asks for your data, probably for commercial purposes.
if I remember well then you get an email with the link to download it.
I use it since 2015, I don't know if it's for the previous ones.
excuse the question, why do you have 2015 and not install it?
company choice to cut assistance to the software, I can not install it alone as I also have the professional vault to configure.
if I have no inventor 2015 does not work?
I can't tell you, I introduced it to the company after my arrival with 2015.
you should hear from the dealer if in 2014 there was already.
problem with drilling cycle.
I would like to make holes with puzzles + the tip out every millimeter.
in hsm there is the special function (at least I think) which is called breaking-partial retract chip.
the parameters to give are:
- pecking dept, we put = 1
- pecking dept reduction, I will not use it and then leave it = 0
- minimum pecking dept , put it equal to pecking dept, then = 1
- % 1, this should be the parameter that makes me return to the tip outside the hole every tot. mm; I put it =5
-chip brak distance, i.e. how much the tip breaks every step of truciole puzzles, I put it equal to 0.2.
At this point I expect to see that every mm of drilling, the tip turns back by 0.2 and then begins the drilling progress, and this does, also arrived at drill depth = 5 (or multiples of 5), should make a complete discharge and I should see the tip completely out of the piece, instead this last function does not.
Can someone tell me where I'm wrong?
