paoanti
Do you have any idea how to produce an internal diameter cylinder 775 mm? from calandra is not very precise. . .
excuse me... cylinder inner diameter 775mm thickness 3/5mm for a height of 915mm with decimal precision, it seems enough. . You need my tax code? :wink:from what I read you don't even know what you have to do or you like to pray for information.
in both cases I pass my hand
When I wrote the bold part there was no.length 915... not very high thickness, it should not weigh too much. we tried with 4mm thickness aluminum rolling. precision to the tenth, roughness does not matter too much; laminate laminate laminate is fine... I forgot, it must cost little:smile:
ah... ok tranquìWhen I wrote the bold part there was no.
Trolleys?length 915... not very high thickness, it should not weigh too much. we tried with 4mm thickness aluminum rolling. precision to the tenth, roughness does not matter too much; laminate laminate laminate is fine... I forgot, it must cost a little:
