industrial customization diameter pipe
  • Thread starter Thread starter paoanti
paoanti
Do you have any idea how to produce an internal diameter cylinder 775 mm? from calandra is not very precise. . .
If you don't know that you have all the information how a user can know that has only one measure?
[MENTION=8445]paoanti[/MENTION]missing the length of the pipe
However see or inform you about the hauliers what kind of work they do
Thank you
only the length was missing.. .
and precision? Need the tenth, the cent, the microm?
and the material? peacock hardware? Airspace aluminum? rosewood?
and the thickness? 5/10? 5 mm? 50 mm? 5 pints of guinness?
and finishing? Laminated crude? as a carpenter glass paper? Is it as smooth as a handkerchief?
length 915... not very high thickness, it should not weigh too much. we tried with 4mm thickness aluminum rolling. precision to the tenth, roughness does not matter too much; laminate laminate laminate is fine... I forgot, it must cost a little:
from what I read you don't even know what you have to do or you like to pray for information.
in both cases I pass my hand
excuse me... cylinder inner diameter 775mm thickness 3/5mm for a height of 915mm with decimal precision, it seems enough. . You need my tax code? :wink:
length 915... not very high thickness, it should not weigh too much. we tried with 4mm thickness aluminum rolling. precision to the tenth, roughness does not matter too much; laminate laminate laminate is fine... I forgot, it must cost little:smile:
When I wrote the bold part there was no.
Trolleys?
I've never read a mix of meaningless specifications like this. seem conceived to waste time on those who read you
