Esselle
Good morning, I'm trying to use the distinct base, but I'm facing a couple of issues I'd like to subject.
1) how to behave in the case of details purchased and then processed?
for example a pinion I buy and then work with drilling and tab.
I have an executive design, in which parts list appears: n° 1 pinion z17 x 1/2". orbene the design code (number part) will be xxxx.xxx.xx but the description will be pinion z17 x 1/2", in the distinct base then being present only one part number, I have to choose whether to put purchased or other and the thing is limiting, because I have to make it to buy the pinion, but also to send to whom to duty the design to do the processing.
2) how can I "appear" the text written in "number part" automatically in the column "description"? this would only serve me for the details inserted by the inventor's library, since for the description in distinct use the column description.
