different base
  • Thread starter Thread starter Esselle
Esselle
Good morning, I'm trying to use the distinct base, but I'm facing a couple of issues I'd like to subject.
1) how to behave in the case of details purchased and then processed?
for example a pinion I buy and then work with drilling and tab.
I have an executive design, in which parts list appears: n° 1 pinion z17 x 1/2". orbene the design code (number part) will be xxxx.xxx.xx but the description will be pinion z17 x 1/2", in the distinct base then being present only one part number, I have to choose whether to put purchased or other and the thing is limiting, because I have to make it to buy the pinion, but also to send to whom to duty the design to do the processing.
2) how can I "appear" the text written in "number part" automatically in the column "description"? this would only serve me for the details inserted by the inventor's library, since for the description in distinct use the column description.
for point 1) you can make a set that contains only one part and then do the work together (e.g., put the pinion in a set and then with work together holes etc.): I took a while to get there:-), it works well.
for point 2) you can duplicate the libraries that interest you and edit them as you prefer, by filling out all iproperties as you want (or setting "forms" that automatically complete the various columns). If you've never done it the first time you spend some time but then it works very well.
Oh thanks for the answer.
then point 1) I tried as you say and in fact in the model data tab appears the assieme and expanding the particular purchased, but I am faced with another difficulty: If I go to export to excel I can only export the "structured" tab or "only parts" and in the first only the assieme appears and in the second only the particular purchased. How do you get both in the same sheet?
Perhaps the structure should be used for drawings and the other by selecting only "purchase" for trade details? I feel twisted.. .
for point 2) I have to study a clutch!
point 1) use the number of warehouse (or a custom property) where you enter the particular to buy and you make it appear in separate.
(ii) the proposal of zac69 goes well (for years I have done so too), unfortunately for export it falls into a broader management problem: If you carry out the structure you have the distinct base, but to make the shorts so as to know how many pinions z16 buy and then how many to work with hole 20 and how many with hole 25 you need a management for not having trouble with nested assemblies. or better, the coupling of the parts works; I didn't find a way to do it.
I would do a second distinct fictitious. Groups for warehouse number (or custom property) and in column amount forks replacement with sum amount.
at this point should be fine
Yes, for the parts it comes out, the mess is with the subassiemi: if I have a composite traverse used in other subaxes that then make up one of the machines of a plant... if the traverse is an inseparable assembly then appears as "only parts" but the components disappear from the bom... I've never managed this directly from inventor.
Hi, I tried and tried, but this procedure can't run, can you explain again?
good morning, not being able to understand the discourse of the number of warehouse, I have equipped myself designing as "inseparable" the axieme that contains the pinion, so in the distinct only parts appear both, with the right quantity, what instead does not happen in the distinct structure, in which the right number of assemblies appears, but not that of the pinion to buy. that I will only export the separate parts, leaving it to immediately understand the relations between the details, which will then be ascertained by hand.
in the iam board management-different components, structured card, right-click on the "structured" tab - properties view - level: all levels, ok and then select the delimiter of the individual voices of the subaxis.
export distinct components -view to be exported: structured and export data: all - ok- export to xls and you will have all subaxis with its components.
thanks to the answer, but the point was not like exporting, but what and how, to have a distinct usable.
