jim78b
I have a part made with welded is present a folded sheet...I make the total weight, I trust blindly...I want to check instead of 39.1 kg must be 45!!!!! How come this flaw?
like body screenshot?if you give some extra data you can make any evaluations, so certainly not...
no I did property and then mass!solidworks does not miss weight. You made some mistakes.
first of all how did you get weight 39.1? Did you make the accounts by hand? with other software? You weighed him in the garage?
then: did you put your hand on something that may have altered the weight? Is there any body with different material?
It is obvious that at least you have to post screenshots otherwise on what you can reason to understand the problem, on the two weights and the word sheet?
mail the file that drake how you can read has 2016 and maybe even a step that to check the weight is also good that
and the result you feel correct as you got it?no I did property and then mass!
Oh, thank you.I did a quick test by opening your file, hiding the chains and making the separate cut with the due sums and providing me 35.515... the value is what you indicate....
