Giancesa
I'm losing my mind about a material update problem. I'll explain. I happen to have to update the density of a specific material, loaded on a dedicated library, all done in the .ipt template. but now opening a component I can't update it with the last modification made in the template: I am forced to enter material editors and change each component the value of density. the same happens to me with the colors assigned to the material: at some point I wanted to change the color of that particular material and I can't update on a piece already shaped. precise that the voice "save" styles is not active but only the voice "update". I don't have permission to update the style bookcases? Also precise that I now adopt the system that to change the material library I go to the .ipt template and I can do everything, but then if I want to align an old file with what I did on the material-color library this I can not do. Thank you.
