creo 3.0 installation
Daniele-san
Good morning.
I would like to proceed with the installation of the new license just purchased (creo 3.0
After entering the code, I'm proposed to select the two options (see attached image)
the first creo essential I suppose is the license
instead the second, create essential home, what is it?
should be the license for laptops, which can also be activated without server support or internet control of the license validity (of course temporarily).
Can I ask you a further question?
I should install the new creo 3.0 license on a machine where creo 2.0 is already present (out of maintenance)
do the installation directories overwrite or for the new installation create new ones?
Thanks again
you should create a new folder automatically (it also recognizes the various "m" without overwriting).
I wanted to try to install but at some point he asks me:
single server (x)
triad (I don't know what it is)
cpu id :confused::confused:
Will it be the mac address of the network card?
If I insert the mac address then... search and continue
configure new software
select the config id
the following products will be installed on the
and should choose on the config id
(default)
.new (not selected)
Go on. . .
the following products will be installed on the cpu id xx-xx-xx-xx-xx-xxx
I'm really confused. .
Is there no installation procedure?
Thanks again
you should by pass the manual license and drag the license file (right drag & drop of the license txt) into the license box and should be able to continue.
therefore with creo 3.0 (as for creo 2.0 and precedent) it is possible to have, through application to ptc, the license file in fomato txt I suppose
being different programs (it is not a "m" release of a product already in maintenance), you have to give the new license in txt, obviously free of charge if you are still in maintenance, but you can't install creo 3.0 with the txt license of 2.0.
yes that was clear
I just thought that with creo 3.0 a web installation should be made
I solved and the procedure is always the same
license request
request dvd or download software
installation
etc.
thanks to all
