falcorsv
Hello everyone, I looked in the forum and also externally but I feel like I didn't find answer to my question.
I clarify my problem, I have a particular for example a cylinder ø100, this cylinder has a
length of es.1000mm of which I made the detailed table. Now I have to place this cylinder
in different assemblies with different lengths e.g.900, 1100, 1200, etc., so that when I make a
change to that l=1000mm the changes I get also on those of other sizes, but of which I do not want to make a table
for other lengths. since I don't want to use iparts and iassembly I thought I would use ilogic so
preset the various lengths, and I managed to do what I wanted but unfortunately I noticed that however
creates a family of parts (which I did not want to use and for which I found the system to make up) but
However in environment together when changing the variable length also changes the variable length
of the particular standard that should instead remain fixed (I hope to have been clear).
practically I would like to achieve something that in sw is called configuration and in itself adjustable part.
Thank you for your attention and I hope someone can help me.
