tabella coordinate
  • Thread starter Thread starter raffaele89
raffaele89
I wondered if it was possible from a 3d file of a pipe to succeed in having a x y z coordinate table of the individual points, or how can I do to have the coordinates... .
to me these coordinates serve to then program a curvetubi so I also enjoy drawing
thank you very much for the interest
in the design there is the function on purpose, I highlighted it in red, asks you to insert the origin, then automatically creates a table with the coordinates of the holes. the table is completely customizable.
perfect. . .
and if you also want coordinates only to bend the tube with the x y z curvetubi??? ?
the table that appears at the beginning where he inserts the values of the tube............ .
I press that I have no professional inventor so I can't try, however in the table asks you the number of points. going intuition would tell me that they are the points in the tube, so you have to take the number of fittings and multiply by 2. then you will have to give the coordinates, the radius of the fittings and the two diameters. not having that function I make a simple swipe. I can't help you otherwise, I'm sorry.
