reggio
hi, I have more and more often the need to get a simplified configuration (which then I carry in step or iges) for customers.
I usually create a copy from which I suspect the parts to hide, but this system I like little because I find myself running 2 files and if the original changes, I must also remake the copy.
I thought then to use the configurations, only that every time they give me problems and turn out long to create, because, as I do, I must select a piece at a time, go into property, and indicate that piece is suspended only for the customer configuration, then go out and repeat everything for each part to suspend ... :frown: (poi punctually when I return in normal configuration, I realize that some piece was suspended by mistake also there: sgrunt:
exists a happier and faster method or explain the step-by-step procedure to select more components and suspend them only in the customer configuration? (always possible ...)
