(autosez 2) soil sections and profiles - automatic extraction
Good evening, I'm sorry if I send out an old topic.
first I wanted to thank gp for the beautiful tools that helps a lot.
I have a problem I can't do the high profile. I'm freaking out. I'm just a student and maybe I'm wrong with something.
mi da 3000 errors :mad: https://mega.nz/#!eqhsgyi!zwvc62rhngubrngusz1hamqvmubgjtdtpxusrgahzk0I can do it at the end but it gives me the initial point and the final point.. I tried from 18 to 22 and I'm really destroyed.
thanks to all
p.s. I loaded the dwg can you take a look at it?
the 3d entity function program, yours are all at 0.00, you can do so:
1) elevates the curves to its share (select the poly and then from properties check the elevation)
2) creates the section polyline on the layer "sections"
3) download as-profilo.lsp (draw profile 2d - for the insertion of the cartilage - calculated by the projection of a 2d polyline on curves of level consisting of polylinees or splines)4) launch autosez
--- data extraction: 2d polylinea on the floor (the one created with as-profile)
--- design section: su cartiglio e indica reference share e first step
Hello, thank you for answering me, like as-profile launch?
and the share I have to give to the level curves is the real one? e.g. 384 or from an internal system (0 ;2;4;6)
then do I have to do it by hand for all 30?
I'm sorry, if I'm ignorant, but unfortunately I'm missing the part of the autocads!
Gp gives me this error
select the profile 2d polyline
error: exit / continue
impossible to call (command) from* error* without first calling (*push-error-using-command*).
we recommend conversion (command) of calls to (command-s).
how to load a lispIf you have to extract quotas, it is clear that they have to be real.
by hand.
:smile:
Hi, I'm sorry about the nabbage, but it's the first time I have to deal with a lisp, it always gives me error: go out / continue
but I followed the perfect loading!
are on autocad 2017
attach the dwg you have modified, with attached management you can do it directly here on the site.
Good evening, thank you for your patience, unfortunately I can't do the profile, or it makes me the mistake or it doesn't make me the whole polylinea,
I think you should do a donation channel anyway, I would gladly offer you a coffee!
the section polyline, as already mentioned, should be drawn on the layer "sections", moreover it must be unique, so you must combine the straight traits with the curved ones.
for this last aspect be careful that the end and beginning of the various traits must coincide.
in the dwg there are a couple of profiles at different scales.
I can't figure out how to install your application. . I do in the command appload, I look for the autosez2, the load, I close, I send the cmd as, but it comes out: "error in dialogue file /appdata/local/temp/vil 004.dcl" line 1: warning: redefining object.
symbol: "dc_settings"
and then autosez says " canceled function" and closes.. .
Help. .
Yes, but maybe I didn't do it properly, in which category of file-options do I have to go insert it?
I don't open the help..
Thank you for doing my profile, but every time I give the command it doesn't work
polyline 2d
Cartridge
level curved layers
premo ok seleziono
But whatever they select always tells me the object is not line or polyline, I just don't understand what I'm wrong... I put the files of the lisp in \autocad and selected the support is the auto loading at startup, but despite everything not goes.. thank you very much!
polyline 2d
Cartridge
level curved layers
premo ok seleziono
the fact that you choose the layer (level curves) means that you do not follow the procedure I have indicated.
I'm sorry if I didn't thank you, but I had to spend a lot of time on topography since she went out to the exam.
I'm practically at school with the road project at 0, using as-profile as you did in the gif, I'm getting high, I'm 380 - 379,80 - 378,54, I know I'm breaking, but I'm very behind and your lisp remains the only hope, the problem that the odds I need in a ratio of 3-1 compared to the distances, if I'm going to understand why
Thank you very much for your patience
I'm getting high, 380 - 379,80 - 378,54
having created a 2d polyline that corresponds to the real profile, when using autosez you have to set the values of scale x = scale y
...the problem that I need in a 3-1 ratio compared to distances
create a block containing the profile polyline, insert it with x =1 scale and y = 3 scale, explode the block, merge lines to recreate the polyline and then use autosez with scale values in ratio 1 to 3
Congratulations, great lisp.
would it be possible to integrate the output with the pendence data? or is there any other lisp able to do so?
Thank you:
Unfortunately, it is not my intention to put my hands on the software again, knowing that I would take the opportunity to make other changes, and I can no longer have the necessary time.
Bye. gp
through description with autosez 2. He blown me. That's great.
However, I am of viet nam and I don't know much about Italian, so I have difficulty using autosez 2. you can share the file lisp for me to edit them in Vietnamese. convenient to use?
mail: anhquangvncc@gmail.comThank you very much
