heat up.
  • Thread starter Thread starter slurpix
slurpix
I tried to search on the forum but I found nothing; use creo/proe for several years but I practically never used sheet metal.
I should simply roll a shaped sheet;
in the sense that I have the development of the sheet (then I start already from a plate) and I want to displace it, only that I can not; I looked for tutorials around but all start from the cylinder and then flatten and never on the contrary -. -
It's probably stupid but I'm losing; I attach the stp file (I use creo 1.0 cmq)
Sorry, I didn't read.
the function to use, is bending.
put the bending line with the recurrences on the arrival board, but instead of leaving 90° and the fold radius = thickness, put 360° and the fold radius as much as you want the rolling.
If you have to do development checks, I suggest you go step by step on the radius of displacement, from a larger one and away approach the final radius you want.
Hello everyone, I have problem with solidworks 2018.
I've got a c-sheet that I'm supposed to dip but:
1) if I try starting from a revolution and trying to turn it into sheet metal does not accept it;
2) if I design the profile to c and then I try to displace it does not make me do it
Is there a simple remedy?
simone
