increase window defaul size "select file"
  • Thread starter Thread starter vavy985
vavy985
when I have to open a new file with autocad lt 2010, in the window opening with the list of all files I can never view the full title of the dwg file name.
How can I do to fix this inconvenience?
a) widens the name column
b) uses shorter names
try to be more precise. How many characters are spoken?
It's about 60 characters, I know it's a lot, but we can't shorten them, and the part I care about is at the end of the name...
I can't have to spread the column all the time!
if it is possible I would like to find a system to block it by adapting it to file names.. .
is a problem of windows autocad has nothing to do with
sin that the office computer technician told me that it is a problem of autocad.. .
because it says they're autocad windows.
I think I'll never solve this problem.
Thanks anyway!
when you opened the window of choice made file you are in the windows explorer. you need to find the way to block the explorer column. and change technical that nn understands a bat
you have to enter the registry editor with regedit.exe if I don't erro, and then I don't remember anymore, it would have to change the values in the autocad sw, I don't remember what point
Please remember. You'd make my life easier. I open a lot of files a day, it's a break!
But... 60 characters in the name of a file?
but not even in the resource explorer window they enter us, at any time.
Anyway... the opening dialogue is resizeable, but the width is not stored between different acad sessions.
means that within the same session (if you do not close autocad) the greatness of the dialogue remains that and you do not need to enlarge it again. If this value is recorded somewhere I don't know, but at least if you don't open up every time autocad a bit of fighting shelter you can have it.
regedit.exe da esegui < hkey current user < software < autodesk < autocade < r... < acad... < profili < mi para che was da ste parte
Forgive me, motocad, but go to suggest a manual modification to the windows register counted by "I think it was right," I think it is worth giving a gun in hand to a blind man saying "The safe is that iron lever moving..." :wink:
:finger:
[MENTION=75121]vavy985[/MENTION] ask the technician,maybe at the head of your technician
you could quietly open the file directly from the resource explorer folder, without having to do the ride from autocad every time.
Moreover the folder explores resources is expandable to the maximum screen against the reduced size of the autocad window.
apart from this, it is right to ask for help, the forum is also done for this (but not only as unfortunately it seems), but you could beat yourself a little too; search column width explores resources on google is not so difficult and in some computer site or windows the answer is there. I say this because reading try to remember you for pleasure from the impression of who rather than putting on his own prefers to wait days that others know or look for him instead of him... and this is not good at all.
