Andrea_Marconi
hello to all and good evening.
I have a question to ask you and for which I write and place 2 images. from the ownership management of if, I do not find to be able to insert the weight/mass column. As you can see, I have inserted everything I need and going to one of a column rather than another with the propspeed I have configured the words to be able to recall and edit at the time of the rescue so that the draft picks up the various values (description, mat, sp etc.) now my problem is purely functional and so I ask you, as it is possible that I can not select and not have the possibility to pull out the whole column. Do I have to activate or create a variable in individual files with a precise call? Thank you for your help.
