Solid User
Good evening, everyone.
I write to ask you if there is a way, in part, to do something similar to what happens in "structures" in assembly environment.
I would need to create a sketch representing the axis of the piece, and then connect to the sketch a particular section. (extruded profile or commercial profile type ipe, hea etc. ) I would like to have the opportunity to change type of section while keeping the work done on the reference plans.
I tried to do "part copy" of the sketch only and then to make a glimpse along the axes, but the method does not work.
I also tried to copy part of the original section file and then move faces. the method works but I do not like the starting length is dictated by the length of the "father" file, I would like to be able to leave only from its section or sketch.
Any idea?
Thanks, bye.
Any idea?
Thanks, bye.
