level on tilted wall
  • Thread starter Thread starter Ricciolina
Ricciolina
Good afternoon to all!
I am a geometra and for my work I want to be always up to date with the news and that's why I have been trying to learn how to use for a few months, and therefore to work with revit.
but I often run into so many doubts and difficulties, asking me so many questions and I hope that some of you are so kind to help me solve them.
in my work to report on revit, I have a house that develops on p.t. with garage and p.1 the civil dwelling that is reached with an external staircase. I wanted to create on the two side walls of the scale, 1 meter high, a step that must then follow the sloped trend of this parapet of the scale. I've done so many attempts, but I'm not succeeding.
Could anyone help me?
Thank you in advance.
If you're referring to a parapet that follows the trend of the scale, you can tell the profile, in the prospectus, and give it the form you want! (if I understand the problem... I agree with tristan in the not clarity of the problem).
I am referring to the parapet of the scale. I'm making several attempts these days but I can't quite understand how to solve the problem.
Do I need to create some components for the railing?
A cover! If you left the architectural template ita among the walls you will find a family of fence walls.... you can start from that and edit it with the section of the "livellino" you go to create ad hoc!
Thank you very much to all! I'll try right now!
If the wall is "inclined" it will not be able to place it on the cover. better if instead put it directly in the family of railings
you the wall where I want to create that tile is tilted.
with the different attempts by clicking on a component, local model and choosing railing (supports or terminals), I managed to create one, or better to understand maybe how to do it.
Am I going well?
with the different attempts by clicking on a component, local model and choosing railing (supports or terminals), I managed to create one, or better to understand maybe how to do it. Am I going well?
I mean. It's the least orthodox and more deceased method, but if you can't do otherwise. . .
Unfortunately as a beginner, for now only so, more or less, I managed to get what I wanted.
because even if I create a profile, on the railing I always charge it horizontally and not tilted as it is the wall of the staircase. Is there a way to give him another direction instead? another trend?
Right! The cover does not follow the sloped wall!
use the railing, loading the cover profile and eliminating the other components. created the railing choose the new host!
