dwg ideas
  • Thread starter Thread starter MioMau
MioMau
hello, there's someone who knows how to do/indicate how to open the saved dwg files with the old i-deas there's a chance to do it? ? .
Thank you
question you already asked.explain why a dwg can't open it with autocad that you state in the profile
hi massivonweizen, I know that I have already asked, but the dwg files saved by i-deas with autocad do not open, you should from i-deas export them to dxf, i-deas do not have it and true need to open these files to bring them back in 3d, percaso you know how to do? ? ?
hi hunter, if you want I can even send you a file, they told me who years ago used ideas that dwg ideas with autocad do not open
- - - updated - - - -even with solid edge I can open them
hi hunter, if you want, I can send you a file, they told me who used ideas years ago
Perhaps you could succeed with the old versions of solid edge, with the current dwg of ideas does not appear among the supported formats.
thanks / hi radio, now opens in dxf with autocad, I need to convert others as I can do? ? ?
as I see it, you have two paths:
1 - take the time machine, go back to ~15 years and buy i-deas:biggrin:
2 - post the files on the forum and I, when I can, convert them to you (always if they are not thousands).
hello radio for kindness,
If you were able to find him somewhere without buying it, then what system does it turn? ? ?
are not thousands, maybe 100, or little +, you convert them to me??, on the forum deove3 do I have to post them?? Or do I send them to wetrafer? ?
Thank you
Thank you
if they are a hundred files, I can translate them to you (without haste); mail here or ( send me a msg in private) the link to download them.
but on what operating system turns ideas?? the first on unix told me, then on win nt, on windows turns? ?
Hello radio, have I prepared them but are 400?? I convert them
depends on the versions, I have an old one that turns on xp.
to the face of the hundred!
If you're not in a hurry, I'll convert them in time.
thank you very much, I send you the link + late, I write you which to start first
thoughto serro 100 pco +
