published blocks_ amrefclose command
  • Thread starter Thread starter Fere
Fere
Good evening,
where I work have installed autocad mechanical 2018.
I have a problem I can't fix.
In previous versions, when I opened a block, after changing it, I closed the same by clicking on the icon that activated the amrefclose command.
now to carry out this operation I am forced to write in the text bar the command.
Does anyone know how to overcome this problem?
You don't understand the problem.
Does the icon work?
Isn't he there?
Do you work in the block editor or are you changing contextually?
Do you use the ribbon or are you a nostalgic who has bars of classical instruments?
Does the icon work?
Isn't he there?
the icon is not present.
work in contextual change
I set the classic bars
then it is not difficult
tools>personality> interface
search the command xrif and block, save change reference and drag it into one of the toolbars
I'll try right in the morning.
given your courtesy and competence I take advantage of it.
when with the mouse I touch a block, autocad highlights it (as if the whole block increased in thickness). I don't know how to explain. Imagine a letter from the afabet that from normal becomes bold.
Is there any way to eliminate this annoying thing?
with some of the system variables of the link you posted I managed to remove the annoying luminescence that appeared systematically at the mouse passage over entities. I also had to manage some items with the check in the selection tab of autocad options. Anyway, I got it.
It's okay with the blocks. I put in the menu bar the icons that manage the lock, add it to the block, subtract to the block and copy in the block.
I wondered if it was possible to unleash this bar from the others and make it appear in the middle of the screen only when you hit a block, as you did once.
Thanks for the advice.
