lock insert on defined points
Sp4rk0
Hi, I wanted to ask if someone has a lisp to apply a certain block on various autocad points.
I have the relief full of points and should replace them with a well defined block, is there a possibility to select them all and apply the block on all or should I copy the block one at a time?? ? Thank you, morning.
Good morning, I am new to the forum and also a beginner in the use of autocad 2016 lt.
I would need a suggestion from you on an operation that is partly described above.
I need to replace points with blocks that have about 7 attributes each...not only... these attributes should go fishing from a project excel.
Do you think it is possible to do all this with autocad lt or it takes the full version?
Can anyone help me through the process?
Thank you!
No way.
the full perhaps, but there is need of solid preparation in lisp or vba to interface with excel.
Lassa loses.
Thank you!
I've been learning to program in autolisp for a couple of months.
I also have some bases of vba
at work I autocad lt 2011
my boss has no extension to subscribe to autocad and pay about 500 euros per year
You don't even have the lisp function compatibility.
ho trovado questo programmahttps://www.bricsys.com/it-it/bricscad/is an autocad with lisp at a cost of just over 500 euros but with the permanent license.I downloaded 2 days ago the trial version for 30 days at my house.
I'm testing it a bit and proposing it to my boss when it's time.
Have you ever heard of this program?? I think it's pretty good.
Do you know better?
Has lisp compatibility? ?
I didn't find her.
if I have to buy a software must have full compatibility with lisp othermetni I care what I already' autocad lt 2011
another thing I would like to learn to create are dynamic blocks.
briscad is compatible, such as progecad, gstarcad, zwcad etc, including vl...
lack acet controls, but it's not a big problem.
we have purchased gstarcad, standard version, lisp but not vba, although through excel or any program that has vba, you fly without problems.
attention to dynamic blocks!
attualmente solo gstarcad supports them (creation and use).Bricscad e progecad solo utilizzo.cap neither creation nor use.
in bricscad said they are working to allow creation in the next releases.
guard qua:http://autocadtips.wordpress.com/2012/03/27/autolisp-replace-selected-points-with-block/(I attach the file contained on the html page if you have problems with copying and paste to create the .lsp since on the page there is no possibility to download)
Good morning, I'm new in the forum and I don't understand about lisp, but I found many in this forum.
by downloading this lisp I replace the point with a block from me chosen but when it asks me the rotation: insert 45 to make the 45° and then select the points (until here all right)
but the block is not rotated of 45° but of 0.79°.
After several tests I don't understand how this passage works.
Someone can help me.
the author of the program got confused in calculating the angle in radiants, it happens (when things are free... )
allego correct version
Good morning, I am a new user, this lisp is my case, I would need a lot, but I have a problem. when selecting the points to be replaced with the block, the block is moved to other coordinates, instead I need the blocks to simply replace the selected point without moving coordinates.
