MassiVonWeizen
do not attach files from external sites. There's a nice button allega file right under your nose
gladly but unfortunately it didn't make me add it, it gave me a strange mistake maybe it was too heavy the file.do not attach files from external sites. There's a nice button allega file right under your nose
I preferred to perform the repetition of the shirts in order to verify effectively the correct path of the chain and especially the correct positioning of the tendicatena and indeed it turns out that the positioning that calculates sw inserting in the belt function a fixed multiple length of the step that I use does not allow me to close the chain completely, this indicates that sw does not perfectly calculate the positioning of the tendicatena or does not couple in the correct way the links to the predetermined path.I see in your set that you drew the chain.
So don't just use the chain function and only create the layout?
I have the same problem I have several chains in my car but they did not recommend drawing them to not weigh everything down.
How did you do that?
even on the curtains, otherwise the simulation will be approximated and you will find yourself with the same problems you have now.thanks to the advice, do you think I should draw polygons only on the pinions or even on the curtains? thanks
a question arises, the curtainr I used is practically a crazy wheel, the polygon I design for the denditor how many sides will it have to have? (for the pinions I obviously did the sides according to the number of teeth thankseven on the curtains, otherwise the simulation will be approximated and you will find yourself with the same problems you have now.
all clear and definitely once defined everything I will opt for this solution to lighten the file.this is how to do a set with the belt without having to draw the chain links.
I put the asola to point out that not defining the length of the chain (by means of the creation function of the same or by using a distance within the chain sketch) you can move the pinion and with a ctrl+q the chain adapts, otherwise if you set the length the pinion will be automatically positioned (unless it comes out from the asola in this case).
search on the catalogs of chains that already exist of ready (bridges, queen, claws....)a question arises, the curtainr I used is practically a crazy wheel, the polygon I design for the denditor how many sides will it have to have? (for the pinions I obviously did the sides according to the number of teeth thanks
That's it.But you made a pack&go of that axieme? I miss the details of the links of the chains
I also tried with fewer t-shirts so that the chain did not overcome but there is no problem. pinions have a fixed positioning for a design speech. those that can be moved are the two curtains, in fact when I imposed the fixed length of the belt equal to 863.6mm the two tensioners self-position along the asola in order to satisfy the length I impose.But how do you control things well with the shirts that stand?
put a lower number of shirts and see that things go back or stretch the lazy whole and you will see that the shirts match
that I will definitely fix it more than anything was just an exemplifying system;the chain with that length in that position cannot be there because as you wrote you also surmounted. I go suggested to stretch the intersection because you see that repetition from a correct coincidence result of the jerseys. even so the repetition is correct only that being a piled you do not understand anything
look how it turns out hiding a couple of magic
according to me is not correct; the two selected shirts are those that should mate, but that do not mate for a difference of 3mm in fact if you melt the intersection of the two selected holes is not equal to the pitch (12.7) while in all the other meshes including those that surmount the entirex mirrors the step. I don't know if I could make me understand.in your example, repeat returns.
or put an example showing your thesis otherwise we discuss airfritta
