Gas85
Hello, everyone, I'll explain the problem quickly. I have to cut plasma a dash into a carpentry and I did the design using inkscape. I then saved as pdf and imported it in autocad because I don't know how to use it. doing so, however, I take all the measures and the carpentry cannot work. I can't set the measuring units in mm, or better do it but pdf is always imported in inches. can someone please give me the dxf from pdf? is a very simple bridge: 525 mm x 400 mm with a dozen round holes in the center, nothing complicated, but I am losing hours without results.. some pious soul?
